The best stainless steel pipe for food and orbital pharmaceutical industry
Machines and tools used in the food and beverage industry or orbital pharmaceutical industry often use stainless steel pipe. Because of the properties of stainless steel is resistant to corrosion, is the best choice in the food field. Therefore, units such as restaurants and catering services give priority to use to ensure strict hygiene standards.
Standard and good stainless steel must have all the elements of material, do not contain toxins, high durability, .... However, not all consumers are aware of these problems. Therefore, our article below will help you have a specific look at stainless steel pipe serving in the food orbital pharmaceutical industry
Why is stainless steel pipe used in the food and orbital pharmaceutical industry?
Because stainless steel has anti-corrosion properties and stainless steel is durable when exposed to heat, water and aggressive cleaning chemicals, it is widely used in the food and orbital pharmaceutical industry. With different parts and levels of contact with food, stainless steel should have the necessary properties such as:
  • Has high durability
  • Does not rust / corrode, does not cause harmful chemical reactions to the human body
  • Easy to clean and disinfect
  • Has good antibacterial properties
  • Heat-compatible because in the food industry, processing and packaging processes are subject to high temperatures and pressures.
The best stainless steel pipe is select to be best in food and beverage industry
For those reasons, many food manufacturers always prioritize the use of stainless steel in the food production process. However, not all types of stainless steel have these features. There are hundreds of different grades of stainless steel on the market, each with its own combination of properties.
Stainless steel material – What is stainless steel?
Stainless Steel – Stainless steel is an alloy, specifically based on iron with a minimum of 11% chromium. Alloys include other metals, namely nickel, and other elements such as carbon. It is the elemental ingredients that give stainless steel its outstanding properties, making it used in a wide variety of industries, especially food industries where the metal will be exposed to extreme environmental conditions. harsh or difficult school. Stainless steel – stainless steel has anti-corrosion properties.
Guide to choosing the best stainless steel - stainless steel for the food and orbital pharmaceutical industry
The choice of stainless steel used in the food and beverage industry is very important because it affects product quality and investment costs of businesses. The right type of stainless steel will help prolong equipment life, reduce maintenance costs or the life cycle of the machine. Each different stainless steel line will have its own characteristics to distinguish and choose from when manufacturing.
To choose the right type of stainless steel: first, it should be based on the industry and the requirements of each type of product. For example, a beverage company will have very different performance needs than a confectionery processor. Second, the stainless steel used will be based on whether they are in direct contact with the material or not? If in direct contact, 316L stainless steel will be selected, but for less important parts, it can be stainless steel 201 or 304, etc.
Types of stainless steel - popular stainless steel is used a lot
There are countless variations of stainless steel – stainless steel that you can use in your life. Each type of stainless steel will have its own characteristics such as high strength, melting point, resistance to oxidation and corrosion.
Some of the parts constructed from 316 or 304 stainless steel in the food and orbital pharmaceutical industry include:
  • Raw material storage tank
  • Filling Faucet
  • Stirrer blade
  • Cap tightening head
  • Turntable
  • And other food contact parts…
Some parts constructed from 201 steel that are less resistant to corrosion include:
  • Protection unit
  • Chassis
  • Conveyor frame
  • And parts that do not come into contact with food
Each stainless steel material - stainless steel will have different outstanding characteristics. Hopefully our above article will help you get a better overview of the popular stainless steel on the market. We hope that the knowledge and experience that we share will be well received by readers.
Where to buy high quality stainless steel pipe for food orbital pharmaceutical industry?
LKS is a unit specializing in providing good quality stainless steel pipe for food and orbital pharmaceutical industry equipment, factory price, prestige. According to the needs of each customer, we always have products with different functional and structural customizations. Always meet strict technical standards to bring perfect, modern and highly aesthetic products to customers.
BLOG
Other Blog
Bài Viết Liên Quan
Trả lời
0
Xem
16
tuongvi.fengyang
Trả lời
0
Xem
21
tuongvi.fengyang
Trả lời
0
Xem
25
tuongvi.fengyang
Trả lời
0
Xem
50
tuongvi.fengyang
