Q
qcj1289596
Many bettors choose to participate in handicap bets when they engage in football betting. This is an exciting type of football bet that provides players with a chance to win. Handicap betting in football is also known as Asian handicap betting. With its diverse playing options, you can easily choose the handicap bet that suits you best. Let's learn some information about handicap bets in football together!
Win big with our expert european football tips
Handicap Betting in Football
Handicap betting in football, also known as Asian handicap betting, is a type of bet that involves a handicap score expressed in odds. The purpose of creating a handicap bet is to balance the strengths of the two competing teams.
There are two forms of handicaps:
Moneyline handicap.
Ball handicap.
Usually, moneyline handicaps are applied first. If the odds between the two teams differ significantly, then the ball handicap comes into play. At that point, the odds between the two teams return to a balanced position. The basic unit of ball handicaps is usually ¼, which is equivalent to 0.25 goals.
Other Types of Football Bets
In addition to handicap betting in football, there are other types of bets to consider:
1×2 Betting (Home-Draw-Away): This is another exciting method of football betting where you predict the outcome of the match, choosing between a home win, a draw, or an away win.
Number 1 represents a home team win.
The letter X represents a draw.
Number 2 represents an away team win.
Over/Under Betting: This is a popular choice among many bettors. Choosing this type of bet can significantly increase your earnings. In this style of play, you base your choices on the following scenarios:
Choose 'Over' when the total number of goals is expected to be higher than the number set by the bookmaker.
Choose 'Under' when the total number of goals is expected to be lower than the bookmaker's set number.
Use betting tips app to win easily : free vip betting tips telegram
Experience in Football Betting
Wintips will share some effective tips for participating in handicap football betting as follows.
First experience: Playing the running handicap
In the event that you consider the form of both teams to be equal, there is no need to apply the difference in strength between the two teams. Playing the running handicap means that when one team scores, the other team quickly equalizes, and the two teams keep equalizing. In this situation, the likelihood of team B winning is quite high.
Assume there are two score changes:
1-0, then 1-1, and later 2-3. In the end, team B wins 2-3.
1-2, 2-2, 2-3, 3-3. In this case, the likelihood of team A winning 4-3 is high.
By remembering such scenarios, your chances of winning bets can be as high as 70%. The winning rate when applying this method can reach up to 80%. If both teams have high rankings, and the away team is given a ½ handicap, then it's advisable to choose the away team.
Second experience: Observing Odds
A characteristic to notice is that when the odds start at ¼, they tend to shift towards 0. When the potential winnings along with the final odds increase by ¼, you should place your bet on the team with lower odds.
In cases where the 1×2 odds show a high possibility of a draw, the Asian odds will increase by ¼.
Third experience: Betting between high-ranking and low-ranking teams
At this point, you should pay attention to the following points:
If the higher-ranked team is significantly better, you can initially choose a 1 handicap. Afterward, gradually decrease it to ¾. You should do this before the match starts 3 hours before. Doing this shows that the higher-ranked team is at a disadvantage, so you should choose the weaker team.
If the handicap decreases and the potential winnings remain high, then you should choose the weaker team. If the handicap is 0.5 and the potential winnings are high, then choose the weaker team.
Fourth experience: Match-by-match betting experience
This experience is based on analyzing specific cases:
Scenario 1: You notice that the odds value doesn't change much or changes only slightly. Typically, this accounts for over 60% of the cases. In this situation, in addition to analyzing external factors, you can focus on the top 4 leagues: EPL, SPL, and the Champions League.
Scenario 2: You notice that the odds for the favorite team are on the high side. This means that the total amount of bets on the favorite team is higher, and the likelihood of winning is around 30%.
View more articles : betting tips app
In conclusion
With these insights into handicap football betting and some other betting tips, you are sure to play effectively. Wintips hopes that you will soon receive high rewards with substantial amounts of money. Experience the thrilling atmosphere of each match and enjoy the excitement of winning your bets!
Moneyline handicap.
Ball handicap.
In conclusion
