Q
qcj1289596
A 1 goal over/under bet is a popular and relatively easy type of bet among all the betting options. So, what exactly is a 1 goal over/under bet? When does it usually appear in matches? How do you read the odds and determine the outcome? In the article below, we will help players answer these questions and share some darts betting tips to help you easily win with a 1 goal over/under bet. Let's dive in to understand this type of bet better!
What is a 1 Goal Over/Under Bet?
A 1 goal over/under bet is a common betting option chosen by many players due to its simpler rules compared to the 1.5 goal over/under bet and its higher success rate. When placing a 1 goal over/under bet, the bookmaker will provide the odds for the total number of goals scored in the first half or the entire match, depending on the competition. The player’s task is to predict whether the total number of goals scored by both teams after the first half or the entire match will be more or less than 1 goal.
To identify an over/under bet on the bookmaker's odds board, look for symbols like O/U, 1H O/U, Full Match Over/Under, First Half Over/Under, Second Half Over/Under, etc. If the player predicts the outcome will be higher than the bookmaker's score, they choose the over (Over) option; if they predict it will be lower, they choose the under (Under) option. Depending on the match result, three scenarios can occur:
No goals are scored: Over loses, Under wins.
Exactly 1 goal is scored: Both bets are refunded.
More than 1 goal is scored: Over wins, Under loses.
Formula for Calculating Winnings in a 1 Goal Over/Under Bet
In football betting, a 1 goal over/under bet can result in a draw where the player gets their money back. The specific formula for calculating winnings for winning and losing bets is as follows:
Winning amount = bet amount x odds (if the bookmaker's odds are positive)
Winning amount = bet amount x 1 (if the bookmaker's odds are negative)
Losing amount = bet amount x odds (if the odds are negative)
Losing amount = bet amount x 1 (if the odds are positive).
To better understand how to calculate winnings in a 1 goal over/under bet, let’s look at the following example:
In the match between Mumbai City and Nassaji Mazandaran in the AFC Champions League, there is a 1 goal over/under bet for the first half with the odds for Over at 0.870 and Under at 0.830. If a player bets $100 on each option, the following scenarios occur:
If the total number of goals in the first half is 2 or more: The Over bet wins with a payout of $100 x 0.87 = $87 plus the initial $100 bet. In this case, the Under bet loses, and the player loses the entire $100 bet.
If the total number of goals in the first half is 1: The bookmaker refunds all bets to the players.
If no goals are scored in the first half: The Under bet wins with a payout of $100 x 0.83 = $83 plus the initial $100 bet, totaling $183. Conversely, the Over bet loses, and the player loses the entire $100 bet.
Maybe you should know : what is an asian handicap in soccer
Revealing the Secrets to Easily Winning 1-Goal Over/Under Bets
Besides being highly entertaining, betting on 1-goal over/under is also seen as a way for some bettors to earn significant money when betting on football online. If you truly want to win and earn substantial rewards, you should keep in mind some strategies for 1-goal over/under betting shared by seasoned professionals below:
Research Team Information
Although bettors don't need to determine which team will win in a 1-goal over/under bet, researching information about the two teams can help you predict the number of goals that will be scored in the match. The information bettors need to focus on includes:
Studying the lineup before the match starts.
Details about the players and their teamwork within the team.
The recent performance of both teams in their recent matches.
The head-to-head history of the two teams.
Strengths and weaknesses of both teams.
Players should gather information from reliable sources to ensure their analysis is accurate. Effective information gathering and analysis will help you make the most reasonable betting predictions.
Choosing the Right Time to Bet
In 1-goal over/under betting, the timing of placing your bet is crucial. Typically, this type of bet is applied in the first half and the first 60 minutes of the second half. Therefore, players need to closely monitor the match's developments to place appropriate bets.
Using Flexible Capital
When participating in betting, players should divide their capital into smaller portions for rational use. If you lose, it won’t significantly impact your life. In betting, unexpected events can happen, and one wrong decision can cause you to lose everything. Additionally, applying a progressive betting strategy can lead to more effective betting. Winning just one round can give you a chance to recover both your capital and your profit.
Always Stay Relaxed and Calm
When placing a 1-goal over/under bet, treat it as a game for entertainment and don't stress too much about winning. Overthinking can cause you to lose your calm and make poor decisions if things don’t go as planned. Therefore, staying calm and relaxed gives you a better chance of winning. During the match, don't be swayed by external comments, as impulsive decisions can lead to mistakes.
The above information betting tips group encompasses all the knowledge about 1-goal over/under betting and effective betting experiences shared by seasoned professionals. If players apply these secrets well, the chances of success are very high. Hopefully, this article will help you understand this type of betting better and use the experience to win substantial rewards on reputable football betting sites.
![Football betting Vectors & Illustrations for Free Download | Freepik](https://img.freepik.com/free-vector/sports-betting-isometric-composition-with-mobile-phone-notebook-with-gambling-application-vector-illustration_1284-78809.jpg)
