Duy Tiên Edge Crush Tester – The Smart Way to Strength-Test Your Corrugated Packaging
pacorrtesting1
When it comes to packaging, strength isn’t optional—it’s essential. Corrugated boxes are the backbone of storage and shipping in industries around the world, and ensuring their durability is key to product safety. That’s where Pacorr’s Edge Crush Tester comes in.
Our advanced testing solution gives you accurate, reliable data on the strength of your packaging materials—so your boxes perform when it matters most.
What is an Edge Crush Tester?
An Edge Crush Tester (ECT) is a specialized machine that determines the edgewise compressive strength of corrugated board. The test simulates vertical force applied to the edge of the material, replicating real-world stacking conditions. The result, known as the ECT value, helps assess how much load a box can handle without collapsing.
It’s a critical metric for packaging engineers, manufacturers, and quality control teams focused on safety and efficiency.
Why Use Edge Crush Testing?
A box that fails under pressure can damage products, increase returns, and negatively affect your brand. Edge Crush Testing ensures your packaging is built to perform.
Key Benefits:
  • ✅ Confirms stacking strength and load-bearing capability
  • ✅ Reduces packaging failure during transit or storage
  • ✅ Supports material optimization – no overpacking, no waste
  • ✅ Ensures compliance with ISO, ASTM, and TAPPI standards
  • ✅ Improves customer satisfaction with consistent, reliable packaging
With the right testing in place, you can reduce costs, prevent damage, and deliver a better experience—end to end.
Why Choose Pacorr’s Edge Crush Tester?
At Pacorr, we understand the critical role packaging plays in supply chains. That’s why our Edge Crush Testing is designed for accuracy, durability, and ease of use.
Core Features:
  • Digital display with real-time measurement feedback
  • High-sensitivity load cell for precise compression readings
  • Rigid, stable frame to eliminate vibration and ensure accurate results
  • Multi-functional design – supports ECT, RCT (Ring Crush), FCT (Flat Crush), and PAT (Pin Adhesion) tests
  • Fully compliant with global testing standards
Built for both laboratory settings and production environments, our testers are made to keep up with your workflow.
Applications Across Industries
Pacorr’s Edge Crush Tester is trusted by companies that rely on strong, dependable packaging every day:
  • 📦 Corrugated box and board manufacturers
  • 🛒 E-commerce and retail operations
  • 🍴 Food and beverage suppliers
  • 💊 Pharmaceutical and healthcare distribution
  • 📱 Electronics and consumer goods packaging
  • 🚚 Logistics, warehousing, and 3PL companies
If box strength matters to your operations, edge crush testing should be part of your quality control process.
Why Partner with Pacorr?
With years of experience in designing and manufacturing testing equipment, Pacorr is a name you can trust. We combine technical expertise with unmatched customer support to deliver tools that improve your packaging standards and operational reliability.
We Offer:
  • ✔ Precision-built, long-lasting instruments
  • ✔ Customization options to fit your needs
  • ✔ Full technical support, training, and calibration services
  • ✔ Competitive pricing with global delivery
  • ✔ A commitment to quality in everything we do
Test with Confidence
Don’t wait for your packaging to fail. Test smarter and build stronger with Pacorr’s Edge Crush Tester Price—your first step toward safer, more reliable shipping.
📞 Get in touch for a quote or live demo
🌐 Visit: www.pacorr.com
