When an infected person talks, coughs, or sneezes, droplets harboring the respiratory virus are primarily released into the air. Wearing or covering a mask is one approach to prevent respiratory illnesses. Why should medical masks be used only once before being thrown away while specialist masks, like fabric masks, can be used repeatedly?
Let's learn about the medical mask with LKS- medical supplies (gloves, masks, surgical items, orbital pharmaceuticals, etc.)...
How do you define a medical mask?
A medical mask, also known as a facemask or surgical mask in English, is a disposable, loose-fitting item that serves as a physical shield between the wearer's mouth and nose and any potential pollutants or pathogens. In the reality,medical masks are used during surgery, seclusion, dentistry, and medical care; they are not shared.
Masks are available in a variety of capacities and thicknesses to protect you from coming into contact with liquids. These characteristics influence how well the mask protects and if you can breathe comfortably through it.
When worn properly, a mask can help prevent the shooting or spraying of droplets that could carry germs (viruses and bacteria) during coughing or sneezing, keeping these germs inside the mask and preventing contact. your mouth and nose once more. Additionally, wearing a mask lessens your exposure to other people's saliva and secretions.
The very small airborne particles that can be spread by coughing, sneezing, or some medical procedures cannot be filtered or blocked by medical masks, despite the fact that they can be effective at blocking droplets. Additionally, wearing a medical mask that does not create a seal between the surface of the mask and your face does not completely protect you from germs and other contaminants.
How many times can a medical face mask be used?
A single use is allowed for medical masks. You should take off your mask, properly dispose of it, and replace it with a fresh medical mask or other form of mask if it is dusty, broken, or making it difficult for you to breathe.
Medical masks ought to be used just once.
Due to the fact that medical masks often have three layers, and in particular, the middle layer serves the purpose of collecting cough droplets that could contain disease-causing germs. Additionally, the mask may filter bacteria and dust, allowing wearers to breathe comfortably while wearing it.
Due to these characteristics, if the medical mask is not removed right away after usage, it becomes a reservoir carrying numerous bacteria that might harm your health.
When is it necessary to put on a medical mask?
To protect your health, buying quality medical masks is neccesary. LKS specialize in supplying reputable and genuine healthcare and medical product ( gloves, masks, surgical products, orbital pharmaceuticals,...) .
The World Health Organization states that you should only use a mask when:
When you sneeze or cough, cover your mouth and nose.
When coughing or sneezing, cover your mouth and nose with tissue to block respiratory secretions. After use, discard the tissue in the garbage.
After touching contaminated objects or respiratory secretions, wash your hands thoroughly.
If you have the flu or a febrile respiratory illness during a time when there are more flu outbreaks in your neighborhood, you should stay at home until your fever has subsided for 24 hours (without taking any fever-reducing medication) and your cough has stopped in order to prevent spreading the illness to others.If the person has such symptoms but cannot stay home, then consider wearing a mask in public or when close contact is possible.
BLOG
- You should only put on a mask if you are taking care of someone who has suspected 2019-nCoV or other respiratory infections if you are healthy.
- If you're sniffling or coughing, put on a mask.
- Only when hands are frequently washed with alcohol or soap and water can masks be used effectively.
- If you wear a mask, you must adhere to the instructions for usage and disposal.
BLOG
