S
suongnguyen
orbital welding is a familiar term in the mechanical industry, this is a specialized form of welding that replaces manual tig welding. the welding process is carried out on the orbital welding machine automatically, continuously and 360 degrees around the fixed object thanks to the electrode.
What Is Orbital Welding Machine?
the orbital welding machine has the main part where the tube holder controller establishes an arc between the tungsten electrode to melt the object and form the weld. the heat generated by the arc melts the base materials and the electrode moves along the junction, gradually dissolving in order to bond the surface area of the material into one.
the 1980s saw a significant increase in the need for orbital welders, which combined with control systems, machine portability and power supply ensured that orbital welders could easily transport between construction sites. this is improved continuously so orbital welding gradually becomes a more advanced form of automatic welding.
WORKING PRINCIPLE OF ORBITAL WELDING MACHINE
specialized orbital welding machines do the job by rotating an electric arc 360 degrees around the clamp and the object to be welded. the adjustment of welding parameters is set through the microprocessor and the settings can be stored and called when you require them.
the use of an orbital welder requires the welder to have the necessary skills to operate the machine efficiently, without the need for special skills.
