phuonglien
what is maintenance work welding? job description, skills required of a welder specifically, let's find out the details of the article below to easily apply for your job needs to bring the best results. when you grasp the job and the skills you need, you can easily grasp the specifics of the job and make the best decision for yourself.
WHAT IS A MAINTENANCE WORK WELDING
maintenance work welding is the practice of welding in the repair, fabrication and modification of various types of equipment. welders will perform metal joining, or cutting metal using extremely high heat and gas, combined with sophisticated welding equipment. the welder is also responsible for inspecting the work for defects, and then repairing or replacing if necessary.
a professional maintenance welder must have prior experience. they must have expertise in the use of equipment and know the welding process. they need to be well equipped with other skills such as hand dexterity, attention to detail and communication skills.
welding maintenance jobs will be available full-time monday through friday. in some cases, welders may be required to work weekends to complete a project they undertake.
maintenance work welding has a fairly stable salary. if you are a professional welder, your salary is quite attractive.
WHAT DO MAINTENANCE WELDERS DO?
MAINTENANCE WELDERS' REQUIREMENTS
if you want to become a maintenance welder, the first thing to consider is:
training
welders need formal training through a college or technical school. a program of study can last from weeks to months. you will learn the math of shop welding, reading blueprints, laying out piping and fabricating structures. after completing a degree or certificate, you can multiply welding projects.
physical requirements
maintenance welding requires strength and toughness. many employers look for candidates who can lift heavy objects. in addition, you may have to work outdoors, in bad weather, or in a small, enclosed area. welder requires hand-eye coordination and the ability to control the torch. vision is also an important part of this job, as a welder you should have good eyesight.
skill
certain skills help welders succeed at work:
- reading comprehension skills. because welders need to study textbooks, blueprints, and trade magazines.
- besides, communication skills are very important. welders can speak and write for technical colleagues or managers.
- math skills. the job of a welder also requires skills in measuring fractions and decimals, as well as applying basic geometry. welders also need to know how to analyze to solve problems.
- finally, computer skills. welders will use computer skills as employers move to new technologies like robotics.
maintenance work welding is a labor-intensive job. to become a professional welder, go through a learning process, as well as accumulate a lot of experience. hopefully with the information and guidance of swiss tech schreiner, you already know how to become a welder. for more information about this job, follow our website swisstechschreiner.com regularly!
SWISS TECH SCHREINER.
like many great businesses, swiss techs. began in a garage. the year was 1990, and lothar schreiner had decided to take his decade of experience in the food processing industry and strike out on his own. with a commitment to hard work, honesty and customer service, swiss tech s. has steadily grown and is currently the largest employer of sanitary welders in west germany. in order to offer its customers in the food, beverage, and pharmaceutical industries a complete range of coverage the company supports a large staff including mobile crews, project managers, engineers, and administrative support.
add: ch 4153 reinach and hcm city vietnam
hotline: (+84) 931 - 386 - 062
phone: (+84) 931 - 386 - 062
+84931386062 ( zalo / viber / whatsapp )
email: swiss.tech.schreiner@gmail.com
Tags:beverage industry
,stainless steel pipe processing
,maintenance work
,Maintenance work welding
,Orbital welding technology
- the following are typical examples of maintenance welder responsibilities. these are the jobs they can perform in their roles.
- practice smaw and fcaw welding skills.
- teach basic welding classes for beginners. they will teach the basic welding processes of metal fabrication, smaw, gmaw.
- weld metal parts with smaw, specified gas welding equipment.
- welding of circles and extensions with fcaw . welding process
- perform welding of stainless pipes and equipment.
- replace and weld the cooling pipes.
- assist the lead instructor in teaching the fundamentals of welding procedures
- work with different shop tools and metal shears.
- arrangement and fabrication of plant material troughs
- alignment and mounting of parts of structural and repair metal products
- repair and manufacture of machine parts
training
skill
,maintenance work
