nguyencuong070421
Understanding Over/Under Bets and Football Odds
What is an over/under bet? How to read over/under odds in soccer. Football is the King sport, you have a burning passion for it football and want to learn about the odds and types of soccer bets to both entertain and add emotion when watching live soccer. So first you have to understand the types of soccer bets. Soccer betting odds are quite complicated, so if you want to bet successfully, you need to have an in-depth understanding. In this article, we will help people learn list of nigerian betting site thoroughly about each type of bet.
Over/under odds
Over/under is one of the easy-to-play types of soccer bets, so many bettors choose it. However, in reality, many people new to soccer betting still do not clearly understand what Over/Under odds are, how to read Over/Under soccer odds, leading to wrong choices. Therefore, in this article, we will guide you how to read Over/Under odds and share some effective experiences in playing Over/Under odds.
This is a bet calculated based on the total number of goals scored by both teams. There are 2 doors for players to choose from. Choosing over means choosing the total number of goals of both teams to be greater than the odds given by the bookmaker, choosing under is choosing the total number of goals scored by both teams to be less than the odds given by the bookmakers.
Over/under odds also known as O/U (short for Over/Under). With this bet, the house will give a number predicting the total number of goals in a match. Players will bet on whether the total number of goals in that match will be higher or lower than the number given by the house. For higher bets, choose over and for lower bets, choose under.
Over/under is considered a fairly simple bet, because you do not need to care about which team wins or loses like European odds, but only need to care about the total number of goals scored by both teams. If the returned result matches the bet, the bet wins.
This has brought newness and many options to people when playing online soccer betting site . But when playing, everyone must remember the rules, how to read odds and play experience to hope to win.
How to read over/under football odds
After briefly grasping the concept of over/under odds, we will guide everyone on some ways to read soccer over/under odds in some of the most common cases we encounter. As follows:
Over/Under 1 and a half balls
One and a half overs and unders in the odds table are usually recorded as 1 ½ or 1.5. This type of bet is often used when betting on over/under in the 1st or 2nd half. Over/under bets also exist but are less common. Specifically, this type of bet will be read as follows:
If a half or match has 2 or more goals, bet on over to win or under to lose.
If the half or match has no goals or the number of goals is equal to 1, the bet will be under or over will be lost.
Over/Under 1 3/4 balls
Over/Under 1 3/4 balls is usually written in the odds table as 1.75 or 1.5 – 2. This type of bet will be defined as follows:
If the total number of goals is 3 or more, the bet over wins, under loses.
If the total number of goals is 2, the over bet wins half, the under bet loses half.
If the total number of goals is 0 or 1, the under bet wins, the over bet loses.
Over/Under 2 balls
Over/under 2 balls are recorded in the odds table as 2. This type of bet is also conventionally defined as follows:
If the total number of goals is greater than 2, the over bet wins, the under bet loses.
If the total number of goals is equal to 2, bets on over or under will win money.
If the total number of goals is less than 2, the under bet wins, over loses.
Over/Under 2 1/4 balls
Over/Under 2 1/4 balls is also written as 2.25 or 2-2.5. This type of soccer bet will occur in the following cases:
If the total number of goals is equal to 2 bets, the over bet loses half the money, the under bet loses half the money.
>> See more: Summary of the most reputable nba betting site philippines today
Over/Under 2 and a half balls
Over/Under 2 and a half balls is often written as 2 1/2 or 2.5. This bet will be understood as follows:
If the match has 3 or more goals, bet on over to win or under to lose.
If the match has 2 goals or less, the under bet wins, over loses.
Over/Under 2 3/4 balls
Over/Under 2 3/4 balls is also written as 2.75 or 2.5-3. In this bet, the rules will be as follows:
If the total number of goals is greater than 4, the over bet wins, under loses.
If the total number of goals is equal to 3, bet over half the money, under lose half the money.
If the total number of goals is 2 or less, the under bet wins and the over bet loses half the money.
Over/Under 3 balls
Over/Under 3 balls will be recorded in the odds table as 3. This bet has the following meaning:
If the total number of goals is greater than 3, the over wins and under loses money.
If the total number of goals is exactly 3, your money will be refunded.
If the number of goals is less than 3, the under wins and the over loses money.
Experience in playing over/under in football
Over/under is a fairly simple type of bet, but to increase your chances of winning when betting, you need to learn more from the experts' experience. As follows:
Select matches and tournaments
If you like to bet on over then choose matches with high scoring rates such as Austria, Netherlands, Switzerland, Sweden, Bundesliga... Or youth tournaments of England, Germany, Australia... Are also not bad choices when enter the account.
Besides, matches with teams in good form such as MU, Real Madrid, Barca, Dortmund... Also have a higher chance of winning.
In case you like to bet on the under, choosing places like Ligue 1 (France), Argentina, Brazil, Portugal... Will have a higher chance of winning.
Analyze odds and evaluate match developments
Before deciding to play over or under, collect and analyze all the following information:
The performance of both teams recently.
Position of both teams in the tournament rankings.
Expected starting lineup, health, injuries of both teams.
The confrontation history of both teams and how many goals the two teams usually score when they meet.
Home advantage, away field advantage, fans, travel distance, match time.
When you grasp the information, you will somewhat predict the outcome of the match. From there, more accurate choices will be made.
So, through the sharing in the above article, we have understood what the over/under soccer odds are and how to read over/under soccer odds. The numbers look complicated but are extremely simple and easy to understand. Players should clearly understand the necessary knowledge above to apply it to analyze and make the best choice for themselves. Hope you enjoy betting and win as much as possible.
Over/under odds
Over/Under 2 balls
Over/Under 3 balls
