nguyencuong070421
The difference between European odds and Asian Handicap odds in football betting
In football betting, there are many types of odds for enthusiasts to choose from. Each type of odds has its own interesting points. So do you know what the difference between European odds and Asian Handicap odds in football betting is? Let's we bookmaker comparison sites with the following betting sites.
What is European odds?
European odds are one of the most common types of football odds chosen by people nowadays. Initially, they were only for the European football betting market, but now they are also very popular in domestic tournaments and in the Asian region.
In reality, European odds are simply the odds for one half or one match. This type of odds has only 3 betting options based on the overall result of the match for the home team - win, lose, or draw. Therefore, players do not have to worry about calculating scores or handicap ratios like other types of bets.
Currently, European odds include two types: half-time European odds and full-time European odds.
What is Asian Handicap odds?
Asian Handicap odds are a very familiar type of odds and are extremely popular among Vietnamese bettors. They are also known by different names such as Handicap odds, Handicap bets, etc. These odds are calculated based on the score of the match with 90 minutes of official play plus stoppage time, except for the result of extra time.
Asian Handicap odds first appear on the internet bookmaker world cup odds board. These odds are somewhat complex with a wide range of different betting ratios. They are primarily studied and developed in the Asian market.
European odds and Asian Handicap odds are two of the most common types of football odds for bettors to analyze, select, and participate in betting.
Although they are widely used, many players doubt what distinguishes European odds from Asian Handicap odds? Moreover, to place accurate bets, players need to understand the essence of each type of football odds to choose the appropriate betting method.
Leading betting experts and professional players have pointed out some fundamental differences when comparing European odds and Asian Handicap odds, which are shown through the following points:
Betting principles and forms
When comparing the differences between European odds and Asian Handicap odds, we must first mention the form of betting and the principle of analyzing odds.
Compared to European odds, Asian Handicap odds have a significant advantage in terms of betting options. Asian Handicap odds allow players to bet on a wide range of specific odds, typically 9 handicap betting options, to increase their chances of winning. In contrast, European odds are limited to only 3 betting options: Draw – Win – Lose, making it difficult for players to find good odds without having a betting option.
Moreover, with European odds, players only need to pay attention to the overall result of the match. As for Asian Handicap odds, players must pay attention to the number of goals scored in the match.
You can see that the betting form and odds offered by these two types of odds are different. And it depends on the extent of the influence of bookmaker free bet on the betting market.
For experienced bettors, European odds and Asian Handicap odds are already very familiar, so it will be easy for them to analyze and choose the appropriate betting method to increase their chances of winning.
Odds calculation of different types of odds
The way odds are calculated between European odds and Asian Handicap odds will show you the most obvious differences.
For European odds, when you win a bet, the amount will be doubled. Meanwhile, for Asian Handicap odds, players will only receive a profit of 0.85. In the case of losing a bet, players will lose the entire amount they bet, not just 0.85 of the amount.
This means that if the winning odds are displayed as 1.9 for European odds, then when you win the bet, the amount you receive will be equal to the bet amount multiplied by 1.9. For example, if you bet 100,000 VND, you will receive 190,000 VND when you win the bet. Similarly, the total amount you will receive is 290,000 Vietnamese Dong (winning bet + initial bet).
As for Asian Handicap odds, the production figures will vary depending on the bookmakers and the country. According to Asian Handicap odds, players participate in betting with handicap odds such as 1, 1.25, 1.75, etc. Depending on the difference in form between the two teams, the odds ratio may change. Although it is relatively more complex than European odds, it is easier for players who want to participate in a wide range of betting options and calculate carefully.
Different names for odds
The difference between European odds and Asian Handicap odds is also reflected in the way odds are called. From there, players can distinguish between different types of odds.
For European football odds, there will be no specific name. However, it is expressed specifically through the symbol 1×2. As for Asian Handicap odds, they are called by various names such as handicap odds, Handicap, and have the corresponding symbol HDP.
