Stainless steel has long been regarded as a "material witch" for the creation of medicinal devices used in space. This kind of substance not only complies with GMP requirements but also has several unique qualities that other metals or alloys lack, making it ideal for the unique requirements of the orbital pharmaceutical sector.
If you are interested in or need to buy orbital pharmaceutical products, you can't go through this article!
What is a stainless steel?
Stainless steel, which is entirely and endlessly recyclable, is a great example of a "green material." Its rate of recovery and reuse is very nearly 100%.
Iron and chromium are combined to create stainless steel, often known as stainless steel. Stainless steel must have at least 10.5% chromium, however the precise ratios and compositions will change depending on the specifications and usage for which the steel is intended.
Other common additives include:
- Nickel
- Carbon
- Manganese
- Molybdenum
- Nitrogen
- Sulfur
- Copper
- Silicon
Throughout the alloying process, the precise alloy composition is carefully assessed to make sure the stainless steel possesses the desired qualities.
The composition of stainless steel does not, however, account for all of its distinctive features. Because the manufacturing process for stainless steel is unique. Melting, carbon removal, adjustment, shaping, and casting are the four main steps in the production of stainless steel.
Why is stainless steel chosen as a material for making beverage and orbital pharmaceutical industries products?
GMP standard for pharmaceutical device materials
The surface of the equipment in direct contact with the drug must be smooth, easily cleanable or disinfectable, anti-corrosion, have no chemical change with the drug, and not have drug adsorption, according to China's GMP rules.
The surface of the device must not react with intermediate or pharmaceutical materials, absorb, change the safety of the drug, change the identity, function quantity, quality, or purity, causing it to exceed statutory or other established requirements, according to GMP regulations in the United States.
GMP has not yet published any documents that are required for choosing pharmaceutical instruments and equipment. Currently, GMP merely offers general guidelines for choosing pharmaceutical tools and equipment, without any specific rules.
However, based on the above text, stainless steel is the most suitable material to meet the contents set out by GMP.
Possesses many important characteristics
possesses a number of crucial qualities. Strict regulatory requirements control the pharmaceutical sector. These criteria have tightened up over time. The manufacturing of instruments, tanks, pressure vessels, pipeline works, and more complex components like orthopedic implants and subcutaneous needles all employ stainless steel.
Stainless steel meets many rigorous standards in the pharmaceutical industry:
- Perfect corrosion resistance, in other words, no rust when encountering water, temperature impacts during use.
- Resistant to high and low temperatures while preserving mechanical and physical properties
- Incredible durability
- Extremely easy to clean, remove bacteria and viruses quickly
- High aesthetics for shiny look
- Low life cycle cost
- Environmentally friendly and easily recyclable materials LKS provides a prestigious, high-class, and good-priced orbital pharmaceutical industry.
Joining hands and cooperating with many famous instrument brands in the world, LKS 360 Exim provides a wide range of orbital pharmaceutical instruments made of stainless steel that meet international standards.
The management and use of pharmaceutical instruments by absolute clients is made safe and worry-free by products that are researched and patented based on top mechanical tool brands.
When you visit the LKS 360 Exim address, you never have to worry about the quality because we are dedicated to offering the best prices along with enticing after-sales warranties for all consumers. Customers that need to purchase in large quantities will enjoy a significant discount.
- Nickel
- Carbon
- Manganese
- Molybdenum
- Nitrogen
- Sulfur
- Copper
- Silicon
