Duy Tiên Struggling with Damaged Shipments or Packaging Failures? Here’s the Solution.
labzenix
In today’s fast-paced logistics and supply chain environment, your packaging needs to do more than just look good — it needs to perform under pressure. Weak boxes can collapse under stacking weight, causing product damage, financial loss, and customer dissatisfaction. That’s where the Labzenix Box Compression Tester comes in.
At Labzenix, we specialize in high-precision testing instruments built to help manufacturers, packaging companies, and quality control teams ensure their boxes meet the highest performance standards.
What Does the Box Compression Tester Do?
The Labzenix Box Compression Tester accurately measures the compressive strength of corrugated and fiberboard boxes. By simulating vertical pressure loads, it helps determine how much stacking weight a box can handle before it buckles or deforms. The result? Stronger packaging, fewer product losses, and better protection during transit and storage.
Why Choose the Labzenix Box Compression Tester?
  • Provides precise, repeatable compression test results
  • Complies with international standards like ISO 12048, ASTM D642, and TAPPI
  • User-friendly touchscreen interface for easy operation
  • Rugged construction ensures long-term durability
  • Suitable for boxes used in e-commerce, food & beverage, pharmaceuticals, and more
  • Helps you reduce packaging costs by avoiding overdesign
Whether you’re designing new boxes, optimizing existing packaging, or conducting QC audits, our equipment delivers the reliable data you need to make informed decisions.
Trusted Across Industries
From retailers and distributors to manufacturers and logistics companies, organizations across sectors rely on the Labzenix Box Compression Tester to maintain packaging quality and customer satisfaction.
Your Brand Deserves Strong Packaging. Test It with Confidence.
Visit our website at www.labzenix.com to learn more about our Box Compression Tester models, technical specifications, and pricing.
You can also message us directly for a quote or consultation. Our team is here to help you find the right testing solution for your packaging needs.
