HCM Stainless steel pipe processing method for good welds by Swisstech
Because stainless steel pipes are more durable than regular steel pipes, this type of pipes are popular. However, in stainless steel pipe processing, employees need a combination of technical, welding, and experience abilities.
Unskilled personnel might easily damage materials during the welding process because of the high cost, which is expensive.
SWISS TECH SCHREINER specializes in providing genuine orbital welding machines willing to share their "method of stainless steel pipe processing for beautiful welds" in order to help you gain more experience and learn more welding techniques.
Benefits and challenges
method of stainless steel pipes processing for beautiful welds
There are advantages and disadvantages to using stainless steel in today's industries.
Advantage
- It is frequently utilized in pipeline engineering and the petrochemical industry due to its great durability.
- It is appropriate for the medical, food, and beverage industries because of the characteristics that stop bacteria from developing on the surface.
Challenge
Manufacturers frequently employ stainless steel to boost production capacity and become more competitive, but there are two considerations to keep in mind:
Choosing the right arc primer and metal compensation can help control the quality of the weld.
- The amount of chromium extracted from the material can cause saccharification, and stainless steel is easily discolored, making it unsightly. - Poor weld quality also leads to more serious and expensive damage.
- Stainless steel offers better insulation than carbon steel, but the heat from the arc is concentrated in the weld pool.
Cost, productivity, and welding form are a few variables that may influence a manufacturer's stainless steel pipe production process.
METHOD OF STAINLESS STEEL PIPES PROCESSING FOR BEAUTIFUL WELDS
Stainless steel pipe processing by orbital welding machines is a mandatory requirement because stability and weld quality are better controlled than with conventional manual welding methods.
The best weld results are achieved using the TIG (Tungsten Inert Gas) welding technique known as orbital welding, which involves rotating the welding electrode tip around the work item to be welded while adjusting the electrode's moving speed and amperage at high and low pulse.
Continuous current control ensures consistent welding results. on tubes with a thickness of 0.5 mm to 4 mm can be welded.
To provide enough shielding gas and balance the pressure inside and outside the pipe, the shielding gas flow can be adjusted. The weld will be concave inward if the external pressure is greater; convex if the external pressure is higher.
To reduce the risk of burning, oxidizing, denaturing, and discoloring the welding part—especially stainless steel pipe (Inox)—the temperature of the welding part is controlled.
Stainless steel pipe seaming will be straight, even, and elegant when done with welding. The orbital welding machine can also weld well and evenly without deforming the welding part, particularly when joining two different materials.
For the installation, upkeep, and repair of pipeline systems (boiler heat exchanger tubes, heat exchangers) in food factories that call for highly accurate pipe welding, orbital welding technology is the answer.
The installation of microbiological stainless steel pipes for the pharmaceutical, cosmetic, food, and beverage industries is just one of the many welding-related projects that our firm, Swiss Tech, has worked on over the years. specializing in the provision and installation of clean utility technology pipelines and pharmaceutical pure water treatment systems.
Contact Hotline by clicking here to learn more about Orbital Orbital Welding Technology and Stainless steel pipes processing.
Bài Viết Liên Quan
Trả lời
0
Xem
9
tuongvi.fengyang
Trả lời
0
Xem
23
tuongvi.fengyang
Trả lời
0
Xem
47
tuongvi.fengyang
