Duy Tiên Pacorr Vacuum Leak Tester – Advanced Technology for Leak-Proof Packaging
pacorrtesting1
In modern manufacturing, packaging integrity plays a critical role in protecting product quality, safety, and consumer satisfaction. Whether it’s food, pharmaceuticals, cosmetics, or chemicals, even a tiny leak can lead to major quality issues. That’s why Pacorr offers a powerful and precise Vacuum Leak Tester, engineered to verify the seal strength and air-tightness of your packaging.
Designed for ease of use and maximum efficiency, Pacorr’s leak tester helps manufacturers identify weak seals, pinholes, and microscopic packaging defects—before they reach the market.
Understanding the Vacuum Leak Tester
A Vacuum Leak Tester operates on a straightforward principle. The test sample is placed in a vacuum chamber filled with water. As vacuum pressure is applied, any leak in the packaging allows trapped air to escape. This results in bubble formation, clearly indicating a breach in the seal.
This visual leak detection method is known as the bubble emission technique, and it is widely recognized for its effectiveness, especially in applications requiring non-destructive or semi-destructive testing.
Why Leak Testing Is Essential in Packaging
Leak testing is a vital part of quality assurance, especially in regulated industries. Faulty packaging can compromise product quality, reduce shelf life, and pose health risks to consumers. Regular testing with a vacuum leak tester helps manufacturers:
  • Prevent contamination or spoilage
  • Comply with global standards (FDA, ISO, GMP)
  • Maintain consistent seal performance
  • Reduce product recalls and consumer complaints
  • Ensure long-term product reliability
Industries That Use Pacorr Vacuum Leak Tester
1. Pharmaceutical Industry
Leak detection in blister packs, ampoules, vials, and strips ensures product sterility and dosage accuracy.
2. Food and Beverage
Used to test sealed pouches, vacuum packs, containers, and bottles for oxygen and moisture ingress that can spoil food.
3. Cosmetics and Personal Care
Prevents leaks in tubes, jars, and flexible packaging, ensuring customer satisfaction and clean product delivery.
4. Chemical Packaging
Detects leaks in containers filled with hazardous or corrosive liquids to avoid safety issues during shipping or storage.
5. Flexible Packaging Manufacturers
Regular quality checks for pouches, laminated films, and sachets during and after production lines.
Working Principle of the Pacorr Vacuum Leak Testing
Here’s how the process works:
  1. Sample Preparation: The test item is placed in the vacuum chamber, submerged in water.
  2. Vacuum Creation: Vacuum pressure is applied using the built-in pump.
  3. Leak Identification: Any leak in the packaging results in the formation of air bubbles.
  4. Result Observation: Operators visually detect and assess the severity of the leak.
  5. Cycle Completion: After the set dwell time, the vacuum is released, and results are recorded.
This method is simple, fast, and doesn’t require complex equipment or advanced operator skills.
Key Features of Pacorr Vacuum Leak Tester
  • Clear acrylic vacuum chamber for full visibility
  • Adjustable vacuum pressure and hold time
  • High-efficiency vacuum pump system
  • Digital or analog gauges for precision control
  • Corrosion-resistant, long-lasting build
  • Fully compliant with ASTM D3078, ASTM D4991, ISO 11607
  • Available in both manual and digital versions
  • Optional data logging and test report printing for documentation
Customization Options Available
Pacorr understands that no two products are the same. The Vacuum Leak Tester Price can be customized to meet your packaging and operational requirements, including:
  • Different chamber sizes for varied sample dimensions
  • Optional automated testing cycles for high-volume applications
  • Integration with barcode scanners or batch recording systems
  • Vacuum range calibration for specific product types
  • Custom materials for testing chemical-reactive samples
From pharmaceutical vials to industrial drums, Pacorr provides tailored leak testing solutions.
Benefits of Using Pacorr Vacuum Leak Tester
  • ✅ Early defect detection helps reduce waste and rework
  • ✅ Improves compliance with packaging and safety standards
  • ✅ Enhances product consistency and customer satisfaction
  • ✅ Minimizes product returns and market-level failures
  • ✅ Supports batch testing or sample-based inspections with ease
  • ✅ Easy integration into production and lab environments
Leak testing is not just about quality—it's about delivering trust.
Packaging Types Supported
Pacorr’s Vacuum Leak Tester is compatible with a wide variety of packaging formats:
  • Plastic and PET bottles
  • Blister and strip packs
  • Foil-sealed sachets
  • Laminated pouches
  • Glass vials and ampoules
  • Cosmetic tubes and jars
  • Vacuum-sealed food packs
  • Chemical containers
Whatever your product type, Pacorr ensures consistent seal validation.
Step-by-Step Operating Procedure
  1. Fill the chamber with clean water.
  2. Submerge the packaging sample under the water surface.
  3. Secure the chamber lid and set vacuum parameters.
  4. Activate vacuum and begin observation.
  5. Watch for air bubbles escaping from the sample.
  6. Stop the vacuum after the test duration ends.
  7. Remove, inspect, and document the results.
This easy-to-follow process requires minimal training and is suitable for operators in QA labs or shop-floor environments.
FAQs – Pacorr Vacuum Leak Tester
Q1: Is the tester suitable for all types of packaging?
Yes, it supports flexible, rigid, and semi-rigid packaging materials.
Q2: Is the testing destructive?
It is non-destructive for rigid items and minimally invasive for flexible packaging.
Q3: How many samples can be tested at once?
Multiple samples can be tested together, depending on chamber size.
Q4: Can vacuum level be adjusted?
Yes, the device allows full adjustment of vacuum pressure and test time.
Q5: Does Pacorr provide after-sales support?
Yes, including calibration certificates, technical assistance, and AMCs.
Conclusion
The Pacorr Vacuum Leak Tester is a reliable, accurate, and easy-to-operate device for packaging quality control. By identifying leaks at an early stage, manufacturers can avoid packaging failures, meet global standards, and ensure product safety.
From pharma to food, and from chemicals to cosmetics—Pacorr delivers trusted performance across every industry. If packaging integrity matters to your business, choose Pacorr for leak detection you can rely on.
