YG 5kg dry powder mixer has a special structure and design for professional dry powder mixing work. The device can mix up to 5kg of powder per batch in a short time. Superior design with no corners and can be tilted 90 degrees.
Introduction to YG 5kg dry powder mixer
The equipment is used for businesses or companies producing pharmaceuticals, powdered milk, confectionery, and cosmetics. However, large-scale production units often use production lines to ensure output as well as reduce costs when using each type of equipment.
Good dry powder mixers are widely used for small, retail production facilities or individuals who produce pharmaceuticals and food to reduce human labor. Save electricity costs and increase work efficiency.
In addition, mixers are also widely used in facilities that produce powdered food ingredients such as cakes, etc. In facilities that produce animal feed and chemicals.
Specifications
Model: YG 5kg
Power: 60W
Working volume: 5-6L
Rotation speed: 0 – 30 (minutes)
Voltage: 220V
Dimensions (LxWxH): 460*380*560 cm
From China
Weight: 28kg
Features of YG 5kg dry powder mixer
The dough mixer is designed in a stainless steel tank, simple, easy to use and clean the machine parts.
Inside the tank there is a stirring wing to help stir the material quickly and evenly, ensuring hygiene and safety.
The outside of the frame is designed with a sturdy, solid steel frame.
Machine capacity is designed to suit the type of raw material, ensuring efficiency.
Machine components are sturdy, durable and safe to use.
Contact Info
Ha Bac Technology Trading & Construction Co., Ltd.
Hotline: 0915796633
Address: No. 9, Lane 170, Thach Ban, Long Bien, Hanoi
Specifications
Model: YG 5kg
Power: 60W
Voltage: 220V
From China
Weight: 28kg
Contact Info
Hotline: 0915796633
