maintaining an orbital welding machine is a necessary component of owning and running an industrial system or work cell, but doing so is a difficult undertaking. to make sure you don't overlook any important steps, it is recommended practice to create a welding machine maintenance checklist.
HOW TO INCLUDE THESE STEPS IN YOUR CHECKLIST FOR ORBITAL WELDING MACHINE MAINTENANCE WORK
look for any liquid or weld spills
this is the first thing on your maintenance work check list. search the area around your orbital welding machine for liquid stains and weld spatters on the ground. spatters are usually the result of a damaged hose, a loose or broken fitting, or hard tubing.
over time, the coating on hoses and electrical wires may crack. when hoses and electrical wires are damaged, the uv light used for welding promotes the breakdown of their components, which results in liquid droplets appearing on the ground. weld spatter, or molten material droplets produced at or near the welding arc, can harm damaged or exposed hoses and wires. your air and hydraulic clamps may become damaged or destroyed as a result of welding spatter accumulation. additionally, spills are also burning a hole through the tubing of your machine and causing a fire.
protective covers like fabric sheaths without restricting movement of your flexible hoses can increase their lifespan . to safeguard hoses that are routed through and on the machine, think about using fabric sheaths, end-of-arm tooling, or stationary tooling stations. when employing high-pressure hydraulic tools, you should also think about selecting a hydraulic fluid that is more fire resistant.
