Phủ Lý Football odds at Wintips - Guide on how to read various types of football odds
nhuy5656
Guide on how to read various types of football odds at clevertips. Currently, the market often offers numerous different odds. This can be confusing for newcomers or even for those who have been participating for a long time. Therefore, our bookmaker would like to guide you on how to read football odds in the most comprehensive way.
What is football odds?
Before delving into how to read various types of football odds for one or multiple matches, let's first understand what football odds are.
Football odds are a set of odds provided by the Wintips bookmaker. They help make matches more balanced and appealing. Simply put, football matches often feature differences in skill level and team strength. This can make matches one-sided and less exciting.
This leads to the creation of football odds. They help narrow the gap between teams in matches. This makes matches much more exciting to watch. Moreover, football odds also motivate fans to follow each match closely and have the chance to win big prizes when betting on them.
How to read various types of odds at Wintips
In football, there are numerous different types of odds. If we were to explain all of them, it would undoubtedly be lengthy and difficult to understand. Here, we will guide you through the key types of odds that are crucial and widely participated in at Wintips. This will make it easier for you to read the remaining odds in a match.
European football odds
The first type of odds we introduce is the European odds, also expressed as 1×2 on Wintips's odds board. This type of odds originates from Europe and has the simplest way of interpretation. In this type of odds, we have different betting options and symbols as follows:
  • Home (1): The symbol for the home team. Betting on this option means choosing that the home team will win.
  • Draw (X): This symbol indicates that the match will end in a draw. Placing a bet on the X or Draw option means predicting a tied score.
  • Away (2): This option involves betting on the away team to win tips bet. The number 2 or Away is the symbol for the away team on the odds board.
Additionally, in this European odds category, we can participate in full-match betting or bet on each half separately. Within this type of football odds, there are also additional betting forms, such as the following.
Double Chance Betting
This type of betting will have abbreviated symbols as follows:
  • HT: This symbol indicates that the home team will win in the first half, but the entire match will end in a draw.
  • HA: This symbol represents that the home team will win in the first half but lose the entire match.
  • AT: This abbreviation indicates that the away team will win in the first half but the entire match will end in a draw.
Asian football odds (handicap betting)
Asian Handicap, also known as handicap betting, originated from Asian bookmakers. Due to the diversity in football odds, this type of betting has gained popularity worldwide. It inherits all the attractiveness of European odds, as it was introduced after the European odds type. Moreover, it offers additional football odds, adding a certain level of allure.
This type of betting is extremely attractive due to the variety of odds it provides. Currently, Asian Handicap is a key type of odds offered by bookmakers and leads in terms of the number of participants in each football match.
So, what makes Asian Handicap or handicap betting so appealing? Let's explore together with home win tips.
The 0.5 or 0:1/4 odds (also known as the level ball or quarter ball handicap)
Surely, you have heard somewhere about the term "level ball," haven't you? That refers to this type of odds. It is one of the most favored among football betting odds. In this type of odds, we have three possible outcomes:
  • Draw: When both teams finish with a tied score. In this case, if you bet on the upper team, you will lose half of your stake. Conversely, if you bet on the lower team, you will win half of your stake.
  • Upper team wins by a 1-goal margin: This scenario occurs when the upper team finishes the match or half with a minimum winning margin. If you bet on the upper team, you will win half of your stake. On the other hand, if you bet on the lower team, you will lose the entire bet.
  • Upper team loses: In this case, if you bet on the upper team, you will lose the entire stake. Conversely, if you bet on the lower team, you will win the entire stake.
The 0:0 or 0 odds (also known as the level ball or even ball handicap)
This is an extremely common and straightforward type of football betting odds. It appears on the odds board only when the two teams in the match are considered evenly matched. In this type of odds, you will choose to bet on the team you believe will win the match. Naturally, if the match ends in a draw or the team you bet on loses, you will lose the entire stake. On the other hand, if the team you bet on wins, you will receive the entire stake in this type of football betting odds.
The 0:3/4 or 0.5/1 odds (also known as the half-one ball handicap)
Among the various types of football betting odds, this type has a slightly different calculation method. This brings a unique element to the game, attracting a significant number of players, according to the statistics from Wintips.
This type of odds is also divided into three scenarios with win-lose calculations as follows:
  • Upper team wins by a one-goal margin: Similar to the level ball odds, if you bet on the upper team, you will win half of your stake. Conversely, if you choose the lower team, you will lose half of your stake.
  • Upper team wins by a margin of more than one goal: In football betting, if you bet on the upper team in this scenario, you will receive double the amount of your stake. On the other hand, if you opt for the lower team, you will lose the entire bet.
  • Upper team loses or the match ends in a draw: This is the simplest scenario among all types of football betting odds. In this case, if you bet on the upper team, you will lose the entire stake, while betting on the lower team will result in doubling your stake.
The 0:1 or 1 odds (also known as the one-goal handicap)
This type of football betting odds is straightforward – the upper team is handicapped by one goal. However, in this type of odds, there are specific scenarios for calculating bets:
  • Upper team wins by one goal: This is a unique scenario in all types of football betting odds, especially in the one-goal handicap. In this case, it is considered a draw, and all the money placed on both the upper and lower teams is refunded.
  • Upper team wins by a margin greater than one goal: In this scenario, the upper team will win the entire stake, while the lower team will lose all the money placed on this option.
  • Upper team loses or the match ends in a draw: In this case, if you bet on the lower team, you will win the bet, while betting on the upper team will result in losing the bet.
The 0:1 1/2 or 1:1.5 odds (also known as the split handicap)
In various types of football betting odds, this type is also divided into specific scenarios for calculating bets as outlined below:
  • Upper team wins by a minimal margin: If you bet on the upper team in this scenario, you will lose half of your stake. On the other hand, betting on the lower team will result in winning half of your stake.
  • Upper team wins by any other margin: Placing a bet on the upper team will result in winning the entire stake in this type of odds. Conversely, betting on the lower team will result in losing the entire stake.
  • Draw or the upper team loses: This scenario is similar to other types of football betting odds. If you bet on the upper team, you will lose the bet, while betting on the lower team will result in winning the bet.
Conclusion
Above is the complete guide on how to read the main football odds on the Wintips website. Wintips ensures that you will be able to understand all the key odds in football betting after going through this article. Please note that you can participate in all types of football odds on a per-half or full-match basis.
Furthermore, we also provide a diverse range of additional prop bets to enhance your betting experience. These supplementary prop bets in football betting will be featured in our upcoming article. Stay tuned, follow, and join in the football betting experience with Wintips.
