Phủ Lý Experience in betting on soccer's handicap market, golden secrets for a hundred matches, a hundred victories
nhuy5656
The over/under bet always attracts players, being one of the most popular choices. However, it's also a highly risky bet, and to accurately bet on it, bettors need the experience of consistently winning in soccer betting. This article provides you with just that.
FAVORITE OVER/UNDER BETS
In the previous article, we clarified the basic and essential concepts of over/under bets in soccer. Accordingly, the over/under bet in soccer is understood as the bookmaker setting a benchmark for the total number of goals/cards/thrown-ins/corner kicks... In the match, counting both teams, excluding results in extra time or penalty shootouts. The player's task is to base on that figure, predicting whether the match will have a total number of goals/cards/corner kicks/thrown-ins... Over or under the bookmaker's benchmark. The over/under bet is often abbreviated as O (Over) and U (Under).
For players, what are the over/under bets that they are truly interested in and frequently play?
Experience in betting on total goals in soccer
This is the most common over/under bet in soccer, second only to each match's handicap bet. Here, the over/under bet on the total goals in a match can be understood as players predicting how many goals will be scored in the match. They then compare it to the benchmark set by the tennis betting forum to predict whether the match will reach the over or under benchmark.
It's worth noting that over/under bets on goals are available in nearly every soccer match, big or small. Due to its ubiquitous nature, the over/under bet on total goals always attracts players, from novice gamblers just venturing into the realm of sports betting to seasoned bettors with decades of experience who can't resist the allure of this type of bet. However, for experienced players, they are savvy enough to understand some rules of placing bets on the over/under bet on total goals.
Experience in betting on total corner kicks in soccer
Considered as a secondary bet, the over/under bet on corner kicks always brings excitement. For seasoned players, this bet can even be more enticing than the over/under bet on total goals. You can understand it as the odds set by the bookmaker for the total number of corner kicks in a match.
Since it involves corner kicks, the number is naturally much higher compared to the total goals over/under bet. Based on my experience in soccer betting, a match usually has over/under odds for total goals ranging from 2.5 to 3.5 goals. However, with the over/under bet on total corner kicks, the odds range from 10 to 11 corner kicks per match.
Experience in betting on total yellow cards in soccer
Similar to the over/under bet on total corner kicks, the over/under bet on total yellow cards is also a secondary bet but highly common. However, this bet is more challenging to play compared to the over/under bet on corner kicks, partly because it's difficult to analyze, and partly because it's more susceptible to manipulation by bookmakers and other organizations. You may have heard about midfielders playing in the English Premier League like Sandro Tonali being involved in yellow card bets when he used to play in Italy. There have been instances where there's a whole network behind Tonali, and bets like yellow cards are easier to manipulate. This poses a significant challenge for players in a game where they are already at odds with the bookmakers.
>> See more: Top-Quality Free buy soccer tips for Today and Tomorrow
Experience in analyzing over/under bets in soccer for winning predictions
To be successful in betting on soccer's over/under bets, it's crucial to have experience in analyzing them. Experience in betting on soccer's over/under markets takes time to grasp its rules, enabling one to learn how to read and analyze the odds accurately, achieving a high winning rate. This experience is essential for both seasoned bettors and novices who are just starting out.
An important note for players to understand in analyzing soccer's over/under bets is that the potential profit is often lower than Asian handicap or European handicap bets. However, the winning rate of this type of bet is usually higher than handicap bets. While Asian handicap or European handicap bets may offer double or triple the stake, over/under bets typically offer returns slightly less than 1, usually ranging from 0.7 to 0.95.
One piece of advice I often share with players regarding betting on soccer's over/under markets is that matches where there's a significant disparity in the strength of the two teams or where one team is playing poorly are not attractive over/under bets. Players can easily be tempted by seemingly attractive odds, but in reality, the risk is very high. Bookmakers are likely to manipulate matches of this nature, exerting significant control over such games.
In reality, betting on over/under markets is often very appealing in matches considered to be difficult, with high competitiveness between the two teams. In matches where the winning odds for both teams are relatively similar, and calculating high handicap odds may be challenging, that's when you should turn to over/under bets. In such situations, according to Betting Betfair experts, over/under bets on total goals, total yellow cards, and especially over/under bets on total corner kicks are easier to calculate. In cases where soccer prediction 100 win gratuit are difficult, and it's challenging to analyze a match, experts suggest that you should choose over rather than under as a player's habit.
Of course, betting on over/under carries risks, with a 50-50 winning rate. In some cases, if you find it difficult to analyze the Asian handicap or European handicap odds of certain teams, experts advise players to turn to secondary bets. This way, the chances of winning are pushed up to the highest possible, at 50/50. Meanwhile, if you follow handicap bets, the chance is only 33%, as it includes the possibilities of win, draw, and loss, whereas over/under bets offer a 50% chance as there are usually only two outcomes.
