S
SolarKite
The Beacon of Azis Solar Amulet is one of the most exciting PoE 2 items for players who love stacking elemental power and turning it into big, bright damage. To help you get the most value from this amulet, here is a simple, easy-to-understand 500-word guide that even a new player can follow. Along the way, we’ll naturally talk about PoE 2 items and when players might want to buy PoE 2 items to speed up their progress. I’ll also share real gameplay experience so the advice is useful, not empty. (And yes—u4gm will be mentioned only once.)
Why Beacon of Azis Works So Well
Beacon of Azis shines when your build uses Solar damage triggers or benefits from stacking multiple hits in a short time. The amulet helps you deal more burst damage, clear faster, and keep your rotations smooth. But to use it correctly, you need the right class and skill setup.
Best Class #1: Witch Elementalist – Solar Nova Spam Build
If you want a simple build that explodes everything, Elementalist is perfect.
Core idea: Use Solar Nova or Solar Burst with high cast speed so the Beacon of Azis can activate its effect constantly.
How to build it:
Gameplay Tip: Always stand where enemies bunch together. Solar Nova clears the entire group with one tap, and the amulet keeps boosting your damage each time you cast.
Best Class #2: Ranger Marksman – Solar Arrow Pierce Build
This build feels smooth, fast, and great for players who enjoy shooting while moving.
Core idea: Solar Arrow triggers Beacon effects when the arrow pierces or chains, causing rapid-fire bursts.
How to build it:
Gameplay Tip: Keep your distance. Marksman loses value if enemies reach you, so always reposition while firing.
Best Class #3: Marauder Warcaller – Solar Slam Overload Build
For players who want heavy hits and tankiness, Marauder is ideal.
Core idea: Use Solar Slam for slow but super strong hits that trigger big Beacon bursts.
How to build it:
Gameplay Tip: Solar Slam hits harder when timed. Use a Warcry before slamming to keep your burst window controlled.
Farming & Progress Tips
No matter which class you choose, focus on attack speed or cast speed so the Beacon of Azis can activate frequently. Keep your defenses balanced, pick PoE 2 items that support Solar scaling, and don’t be afraid to buy PoE 2 items if you want to finalize your setup faster.
How to build it:
- Main Skill: Solar Nova
- Support Skills: Cast Speed, Area Damage, Added Solar Damage
- Defenses: Energy Shield recharge + Fire Resistance stacking
- Key PoE 2 items: High-ES chest, wand with Solar scaling, rings with cooldown recovery
How to build it:
- Main Skill: Solar Arrow
- Support Skills: Pierce, Attack Speed, Solar Damage
- Defenses: Evasion gear + Anti-ignite flask
- Key PoE 2 items: A bow with chain chance, quiver with Solar modifiers, high-evasion armor
How to build it:
- Main Skill: Solar Slam
- Support Skills: Increased Area, Solar Damage, Melee Power
- Defenses: Armor stacking + Life regen
- Key PoE 2 items: Two-hand weapon with Solar scaling, armor with flat life, belt with strength
- When gearing, you often need several PoE 2 items with Solar modifiers. Some of these can take time to drop.
- If you don't want to farm everything yourself, some players choose to buy PoE 2 items to finish their build quicker.
- Upgrading your weapon early gives the biggest power spike—don’t wait until the endgame.
- For swapping gear or buying crafting materials smoothly, many players use u4gm once, especially early in a new league.
